got it done lookin good
since clutch bolt was broke off about 1 inch out from the puller threads in clutch shaft no way to pull clutch.
to get moveable sheeve off used two pieces of 2x4 fir cut at an angle going from about 1.7 inches to 2.3 inches about 3 inches long each. used a hammer to pound these in back and forth where the belt goes.. on opposite sides between the sheeves, and with not much effort the moveable sheeve came off. yeeaaahhh
so now just the clutch shaft with the broken bolt about 3 inches in, crap how to drill that out trying to keep the bit centered and not taking out the puller threads in clutch shaft??
went to local recycle scrap yard and found a piece of pipe that would fit nicely in clutch shaft and go over the broken bolt with the correct inside diameter for drill bit. this was like magic as easily drilled out bolt past puller threads and then used water method to pop clutch off!!!!! yeeaaahhhh
once clutch was off used cut off wheel to nicely cut off remaining clutch bolt at crank snout. then carefully center punched and worked my up with drill bits drilling out the frozen threads of the bolt in the crank snout. after daring to go no bigger on drill used dremel with carbide cutter bit to slowly grind bolt threads furthur till could see "shadow" of snout threads. then carefully started tap to slowly "Break" out the frozen clutch bolt threads.
went slow and wallah......good to go . put my new rooster recommended ramps in . torqued the clutch back on.
Would like to thank I 90 motorsports for the support , should have had them do it, but i like wrenchin too.
