RH powder bog ?!
CO 2.0
2,994
Fort Collins, CO
I got out today 4 feet of pow over the hood. My dealer had his Mountain cat out and was getting bogs all day long not necessarily on RH turns. was pissing him off. I didn't bog once. I sealed up my intake and nose cone with silicone last night.
Wyoboy was with us. His super high running boards on his 16 w dropped case actually do help not hang up in pow. He lifted them 3" higher than stock. Requires ape hanger risers but was surprised how well it worked in that deep snow
Nov 5, 2014
66
14
8
K serious question here.
How do I go about blocking this hole off between the steering post and the google bag?
Is there a product or do I have to invent something?
I don't want any snow in my engine bay.
Thanks
Sent from my FRD-L14 using Tapatalk
CO 2.0
2,994
Fort Collins, CO
I really don't think the hole behind the steering post is the problem. I've used the plastic grate on all my past proclimbs including this MC to let out under hood heat, and I didn't have the bog today in stupid deep pow. My dealer had the goggle bag on his MC and had bog. The intake on the bottom needs to be sealed up on the big gap on the inner sides with silicone. I can't really see the gap on outer side or if there is even one but I jammed a bunch of rubber weather seal in that side just in case
Nov 5, 2014
66
14
8
Not saying it is the problem. I am just not fond of having moisture in my engine bay.
Excuse my ignorance here but I am new to Cat this year.
So there is a grill that I can get?
Maybe glue frog skinz to it?
kidwoo
2,630
1,875
Probably looks like a monkey fvcking a football on that thing.
I want to see pics.
Of the sled I mean. Not him.
acwyo
81
11
8
Douglas, Wy
Yep sealing the intake was the trick. Mine got a quick tape job last night before heading down. Taped all sides of the lower intake to test it out. No bogs all day in super deep pow! Also have Diamond S can and I did not cut the outlet down yet and I had no bogging issue due to the exhaust either. My dealer was there and said he will be getting with cat on the intake issue.
And as far as the boards Wyoboy changed up, they fell way different and yes need app hangers, 3" higher boards mean 3" higher bars, but the function in deep pow was considerably better, way less drag!
SnoPro1000
283
115
I’m sitting here thinking,
With the front intake would that sticky foam stripping work?
Like the stuff you can use for truck box toppers. Comes in different thicknesses and different sizes just a thought what do you guys think instead of dealing with silicon
Also, there’s the gauge. I dunno if when popped off if behind it is the intake but the other day my sled rolled and the gauge popped off was simple to pop back into place but after thinking at work if behind it is intake and it simply pops on and off without a seal could be an other problem area
TNTCOPP
2,163
380
83
53
Buckley, WA
Funny you say that foam - that is exactly what I was going to get at the auto store today. That stuff sticks really good.
Ideally would like a mesh type Gorilla Tape, or FrogSkinz material.
I can not believe that gap at the top of the intake.
Oh wait, yes I can.
J
jim
635
Boise
Same as always...powder bogs are worse on the right than the left due to pipe exit. And the intake will clog and/or injest snow in these conditions making it worse. Even if no bogs, the right hand sidehills do rob power...adds a lot of backpressure and throws things off. I have also found that running too high of octane for the elevation makes bogging worse...the high octane doesn't burn as readily.
TNTCOPP
2,163
380
83
53
Buckley, WA
So pull your hood off , turn the lights off , stick a flashlight in the nose intake of the hood and you will see where you need to seal off. Mine was in the very front of the nose and one more area about a foot back where a screw goes in. Be sure to face the flashlight from the nose back towards the gauge too, that's how I saw the second area I need to seal up.
Nov 5, 2014
66
14
8
I donno if I would silicone it, talking with my dealer there is supposed to be an update.
Going with tape for now.
See what they come up with.
Sleddogg
109
32
Dayton, WY
Also make sure the tabs are in on your vents themselves. Enough taking on and off,mine weren't seated correctly.
Sent from my Pixel 2 XL using Tapatalk
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
The right side wasn't assembled correctly so it had a gap. I taped it for now. I Should have taken a pic with the hood off and the gap.....
Oh well, here is an assembled pic.
Mountain Cat
Sleddogg
109
32
Dayton, WY
Anything New
Does anyone have any news good or bad with the issue?
Rode mine 2 days and had bad bogging issues. I'm not even sure it has to do with the powder anymore. I was going across a flat mountain lake and it would bog. Have to really chop the throttle to get it out of the bog. It screwed me on side-hills and trees many times! I have 7 hours on the sled, almost seems too rich?
I've taped and sealed everything possible too.
summ8rmk
Most handsome
12,368
6,039
yakima, wa.
Have u told ur dealer about the issue? Curious as to what the dealers think.
I just seen u have 7hrs. U may not be out of breakin? Adds fuel and oil for 6hrs of ridding time.
Mountain Cat
richardderkevorkian
634
356
Soldotna AK
This sounds like the issues the 600 c tech has had for years that cat wants to pretend isn't real. I was hoping the fuel rail dampenener was the fix, maybe not
fudge313
528
88
Finland
Your in breakin mode.....
L
leeindubois
Nov 20, 2007
496
42
Dubois, Wyoming
bog
Same issue with my sled. I tried sealing the lower intake with silicone and upper by goggle bag like everyone suggested with black tape. Sled is still bogging bad and not just in powder. Even did it on the flats a few days ago.
I have roughly 175 miles and it is out of break in mode. not sure what to do anymore... Any ideas?
I have heard of a sled that burnt down from this issue this year with snow in the intake...
