C
Just finished up my EVO mod stuff and decided to set up the clutch by creep. As stated above, I ended up with the top of the belt cogs approximately 1/16" below the top of the secondary to obtain the proper "creep" belt deflection. Rule of thumb has always been to place the bottom of the belt cog even the top of the pulley, with the cogs exposed, and that would get you close. Not so with this setup. Primary appears to be shifting out all the way so I can only assume the factory belt is too short, or the center to center distance was set wrong from the factory. This sled is brand new, has not been on the snow. Besides starting out in 2nd gear, I could see where the belt could bottom out in the secondary before the primary is fully shifted out :face-icon-small-fro
What are you guys finding for your belt settings?
