Crazy Mountain extreme drive system
M
mngoat
30
Minnesota
Had an early version and it didn't like the HP i was throwing at it, about 190. Lower bearing and lower shaft issues. I know mark has updated alot of the stuff that i had issues with but havn't run any since my original one. Also had issues with the wider belt(had a buddy start one on fire once) but i think the narrower belt has helped alot.
POLZIN
1,546
Farmington NM
I have one and its Ok IMO not worth the $$$ unless you working on an older sled and cant get a D&R for it. Thats how I ended up with mine. I have it in an s chassis skidoo it was a PITA to install.
J
Jkinzer
2,752
628
Lewiston, Idaho
have one on an 1155 psi motor in a cmx chassis, seems to work great... go through 3 or so belts a year on her tho, you looking at putting it on your 900?
St. Hellens rider
117
19
18
39
washington
i have been around three different cmx sleds. one with a 1200, one 1085, and one 995. all ran like hell. asked my old man how he liked the drive on his 1200 and he said if hadn't come on the sled i wouldnt buy it. have to completely let off the throttle when you jump or it will snap the belt when you land.
