Revving out at 7,000rpm's
tdietzler
New member
12
2
3
31
Larimore, ND
Up in Steamboat riding, I'm only getting 7,000rpms out my Boondocker assault and then it sounds like a bog. Up around 10,600 at 6-8lbs on 100LL fuel. Any suggestions on this? Checked the basic things, plugs and belt reflection. Visually everything looked pretty good.
likkerpig
1,298
271
83
Power valves sticking? That's right when they're supposed to open. Sounds like a lot of octane for 6-8lbs for that elevation, should be OK cutting it back to a couple gallons of av/tank @6-8lbs. More for insurance than anything at that point, certainly should not need 100%ll on that psi at that elevation.
tdietzler
New member
12
2
3
31
Larimore, ND
boot slipped off of the Intercooler, easy fix thank god!
New problem: I turned the boost up to 10lbs and made a hard pull and after I let off it idled way down to 1100-1300 then it would shut off unless you feather the throttle.
It did this twice, then coasting downhill it's doing the same crap.
likkerpig
1,298
271
83
Not extremely familiar with the boondocker, any chance the fuel settings need to be tweaked on deceleration or lower rpm bands? Been a lot of years since I played with a boonie box, sorry I don't have much to offer...
tdietzler
New member
12
2
3
31
Larimore, ND
Yeah I'm don't have the boonbox down 100% but pretty close. I've talked to a few ppl and they were thinking its a reed issue. Opening up fine on high Rpms but not closing for the idle rpms
B
Bacon
1,352
Napoleon, ND
Or your leaning it out on the long pulls and then it won't idle. Dial it back down and ru 7-8 psi and see how it works.
