pro rmk silber turbo oil delete?
I
Jan 1, 2015
2
Hello all. Quick question regarding the oil delete kits for silber turbo on my 14 pro. I recently purchased this sled and noticed down by the oil tank and pump it was a little leaky. Before I bought it a buddy and I did some research and found that there are a couple minor things when it comes to the pump and tank as far as it leaking. I am just wondering if anyone has purchased the delete kit and if so are you satisfied? Is it worth the money? Or is it fine just running it the way it is?
B
Nov 12, 2013
55
12
8
I did the delete kit. IMO worth the money. Saves some weight and simplifies the system. One less component to fail on you and damage your turbo. If you have the old style kit with the journal bearing turbo, I dont think you are able to do the delete (contact Justin about this). If you have a kPa ball bearing turbo, youre good to go for the delete. It's relatively easy to install and can save you some headaches.
D
doobie
Oct 13, 2008
128
44
Cochrane ab
they work great. but $200 is steep for what it is. we now build our own. but again the silber delete does work great.
Merlin
1,183
300
83
Medicine Hat, AB
Regarding the use of the factory oil injection pump to lube the turbo - Is everyone(kit manufacturers) "dead heading" the oil flow at the turbo?
Even though the factory injection pump makes very little flow, you are still relying on the oil being forced past the shaft seals to bleed off the pressure. Doesn't seem like the best set up.........
Has anyone tried installing an appropriately sized relief valve(maybe set at 35 PSI-ish) on the turbo drain & then routing the return of the relief valve either into the intake or even back to the oil tank?
joshkoltes
3,842
1,170
ranchester, wy - nashua, mn
im not familiar with which oil delete your talking, but I bought the self lube turbo from him. no oil lines whatsoever. its exactly what I was looking for and waiting for.
yes you can run it the way it is, but for me I get stuck often and roll it out. oil gets everywhere. now its one less thing I have to keep track of oil level on.
im pretty sure they came out with an updated cap that solves the problem too?
my old cap (slightly modified)
tested proven dang near perfect
looks way cleaner
I was having leaking trouble with the cap on my '12 kit and upgraded to this selflube after burn down trying to tow a tm-1000 out on a 2' day.
P
purepolaris600
358
84
Elkader iowa
looks way cleaner
Silber no longer has a seperate oil tank for turbo they run off of motor oil pump so No worry about oil spill.. The oil tank delete if you have a ball bearing turbo you get rid of the tank and run a oilline off motor oil pump to turbo Then is injected into compressor. No extra tank no spill no mess no need to worry about a extra oil pump just full your oil res. every morning like normal good to go.
likkerpig
1,298
271
83
I'm installing an external gate now, don't see any return line to run back into the compressor.... Thought the non-axys Sleds were deadheaded. Could be wrong though....
roughrider99
1,805
252
83
33
Fernie,BC
35 psi is enough for a journal bearing turbo. ball bearing turbos just need a very small steady drip of oil.
Merlin
1,183
300
83
Medicine Hat, AB
We also deadhead it
Can you comment on why "you" chose to dead head the lube circuit?
