T
So I set my tps per the video, and then adjusted the final reading to .93 for low elevation but when I start the sled the idle is around 2300 rpm. Have not been able to find any air leaks, TB boots are good, plugs seem to be a nice light brown color. So while the sled is running I backed out the idle stop screw to lower the idle rpms to 1500 rpm. Am I missing something when setting my tps? I built the tps tool with directions from this site and with a new 9v battery I am getting 5.01v through the home made tool.
I know my base tps voltage is now less than the .93 I started with because I lowered my idle with the idle screw. Do you think this could cause my low speed bog/flat spot?
The sled runs great from idle to 3600 rpm and above 4400 rpm but has a bog/flat spot between those rpms. No check engine light, new plugs, new plug caps, new fuel filter, fuel pressure is spot on, and compression is good.
Any other ideas? Sled is a 2006 fusion 700
