Upgrade to Premium
Yamaha: 4-Stroke Includes all Yamaha 4-strokes, Nytro, Apex, Phazer, etc
Reply
  #1
Old 01-03-2012, 05:21 AM
snowmanx's Avatar
snowmanx snowmanx is offline
Currently: Excited about taking the M1000T for a rip!!
snowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond reputesnowmanx has a reputation beyond repute
Default Is there a failsafe mode(limp mode) on Nytro if overheat going down the trail?
So if a guys is going down the trail and coolant gets too hot, the yellow warning light comes on? How do you differenciate it from just low fuel light, which is the same yellow warning light right?
Will the sled go into limp mode if it gets too hot down the trail? Or will it just let you keep driving until it gets too hot and you toast your engine?
Thanks.
Just trying to learn about this new sled of mine!
BTW....IT FRIGGIN RIPS!!!!lol What a blast...MCI express at 18#LOL WOW
Anyways, had to throw that in.
__________________
If you're not just a little scared, you're not high enough!!!!
Custom Vanamburg TM1000
Rate this post: Yes | No
  #2
Old 01-03-2012, 08:46 AM
srxspec srxspec is offline
Currently: Not set.
srxspec has a reputation beyond reputesrxspec has a reputation beyond reputesrxspec has a reputation beyond reputesrxspec has a reputation beyond reputesrxspec has a reputation beyond reputesrxspec has a reputation beyond reputesrxspec has a reputation beyond reputesrxspec has a reputation beyond reputesrxspec has a reputation beyond reputesrxspec has a reputation beyond reputesrxspec has a reputation beyond repute
Default
The warning light will come on, but the only "fail safe" mode for overheating is if the sled is at IDLE it will shut itself off if it sees and overheating condition. If you are riding it and it overheats it will not put itself into any fail safe mode whatsoever!
  #3
Old 01-03-2012, 10:12 AM
snowmanx's Avatar
Default
WOW, that's too bad, most of the 2 strokes will go into limp mode won't they?
__________________
  #4
Old 01-03-2012, 12:51 PM
Mister907 Mister907 is offline
Currently: waitin to ride...again
Mister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond reputeMister907 has a reputation beyond repute
Default
if you look above the yellow light you will see either a gas pump, oil can, or temp sign. that will tell you what the yellow means at that moment. if youre goin down the trail and see the temp signal, shut er down n let it cool before checking coolant and restarting. or hit the gas n wind cool it!... wait, you might want to be SURE there is coolant in there before wind cooling it. in the spring on a nice warm day my light will come on, but as long as im sure there is coolant in there, a little more speed cools it right off. or get your arse back in the snow!! not sure about a "limp" mode, never been there.
fix as much as possible
  #5
Old 01-03-2012, 02:36 PM
wilmot wilmot is offline
Currently: waiting for winter
wilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond reputewilmot has a reputation beyond repute
Default
If your just puttin around on the trails they will over heat. when that happens hit the throttle they need air and snow to stay cool...
  #6
Old 01-03-2012, 03:58 PM
snowmanx's Avatar
Default
Good to know, thanks guys. I think it was loww fuel, as I put my extra gas in and it never came on. Coolers were wet, I've got the Van amberg tunnel with extra cooler.
By the time I got back to the truck, the cooler was hot to touch ( a lot hotter than a 2 stroke,) even the top of my tunnel was hot, but no warning light came on.
I just don't want to be over heating this sled, too much bad luck with 2 strokers and I don't want any issues with me "reliable" 4 stroke.
__________________
  #7
Old 01-03-2012, 08:18 PM
BordnBill BordnBill is offline
Currently: Not set.
Basic Member
BordnBill has a reputation beyond reputeBordnBill has a reputation beyond reputeBordnBill has a reputation beyond reputeBordnBill has a reputation beyond reputeBordnBill has a reputation beyond reputeBordnBill has a reputation beyond reputeBordnBill has a reputation beyond reputeBordnBill has a reputation beyond reputeBordnBill has a reputation beyond reputeBordnBill has a reputation beyond reputeBordnBill has a reputation beyond repute
Default
I just installed a Ulmer Water Temp Gauge, so now I know when I get too hot. I have a radiator delete and only a tunnel cooler, so I need to watch temps when in low snow conditions.
The Following User Says Thank You to BordnBill For This Useful Post:
Mister907 (01-04-2012)
  #8
Old 01-03-2012, 09:54 PM
Thistledoo's Avatar
Thistledoo Thistledoo is offline
Currently: Bring on the POW!! and dont be shy!!!
Thistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond reputeThistledoo has a reputation beyond repute
Default
ya a temp gauge is nice....mine on deep days runs 150....then 180 on trails and the light doesnt come on until like 212 or something dumb...I never let mine get there.
running a CR tunnel with rad delete. Pulled a guy out last ride and i stopped a couple times to fill the gas rack with snow and it didnt take long to melt it
but ya easy to plumb in a gauge.
__________________
MCX BOV springs to make the BOV actually work proper...pm me for details
Copper exhaust doughnuts for rear mount yamahas...pm me for details
The Following User Says Thank You to Thistledoo For This Useful Post:
  #9
Old 01-04-2012, 01:48 AM
Default
got a link to where a guy could get one of them thar gauges?
...never mind, found it a few posts up...http://www.ulmerracing.com/.
thanks guys
  #10
Old 01-04-2012, 08:20 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M1000 Limp mode HELP!!!! Thread Starter — 257 stw Forum — Arctic Cat: M Series Replies — 24 Last Post — 02-13-2012 09:16 AM
Thread — limp mode.. Thread Starter — RMKsledmonkey Forum — Polaris: EDGE Replies — 9 Last Post — 01-23-2012 03:09 AM
Thread — Limp Mode Bypass Thread Starter — Corndog Forum — Polaris: GEN 2 Replies — 1 Last Post — 12-03-2011 08:56 AM
Thread — Limp Mode ? revving problem Thread Starter — Juggs Forum — Ski-Doo: XP Sleds Replies — 3 Last Post — 01-31-2011 06:57 PM
Thread — 900 limp mode help please!! Thread Starter — jlloyd Forum — Polaris: 900 Replies — 9 Last Post — 02-12-2010 10:17 AM
no new posts
