I was just reading in the polaris forum about a guy comparing his old edge with his new dragon and asking why the edge performed better. More than once someone posted that button clutches work better. This got me thinking as this isn't the first time I've heard this. A buddy built an edge poo with a psi engine and also mentioned to me that the button clutch worked better.
I suspect the reason people say this is because the sled is a little slower to shift out which keeps it in a lower gear a little longer. Which aligns with my own experience. A few years ago I had a roller conversion for my 670X and I could never make it get out of the hole like the goodwin buttons on a 47* helix.
Now I'm running a cat with a bit of HP and have the same problem. The clutch shifts to fast and it seems like I'm in 2nd gear when the engine is still building rpm. The cat engine doesn't have exhaust valves (more weight and complexity, and it already has plenty on the bottom end) so that may contribute to the problem but it doesn't make any less HP than the 670X which has a bit more power for the first 20 feet.
I've tried a number of helix setups to resolve this but it seems that using shallower helix angles always cause my midrange to suffer and can even cause the belt to slip in the primary.
This leads me to believe that I'm going about this the wrong way and that I should spend more time in the primary when setting up how it should shift and leave the secondary just to the backshift and keeping the belt from slipping.
I ordered 2 new primary springs with higher initial load which should cause the sled to shift slower and at a higher RPM out of the hole which make fix the problem, but it might also cause my engagement to be too high and cause problems there.
So the question is, who else has noticed problems with the sled shifting too soon using roller clutches and what have you done to resolve it?
