Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
Reply
  #1
Old 10-11-2018, 08:36 AM
Hjalti_GTO Hjalti_GTO is offline
Currently: Not set.
Basic Member
Hjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond reputeHjalti_GTO has a reputation beyond repute
Default Small crack in rails. What to do. Can i fit 14 rails in my 13?
Notised a small crack in both my rails. Whats the best braces / Rails Stiffeners for those sleds?
Its 2013 m800 162"
Pics
https://ibb.co/iX11tp
https://ibb.co/eWGZDp
https://ibb.co/hu1O69
https://ibb.co/hAJEDp
https://ibb.co/jcVi69
Rate this post: Yes | No
  #2
Old 10-11-2018, 10:12 AM
Storskogen Storskogen is online now
Currently: Not set.
Storskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond reputeStorskogen has a reputation beyond repute
Default
Quote:
Its 2013 m800 162"
Pics
Maybe it is also a good idea to drill the cracks to stop them from eating further down? On 2015 they put braces on all M sleds from factory.
M800 -13, Speedwerx full exhaust, PCV. BC WT 660T -06
__________________
M800 Ltd -13, Speedwerx full exhaust, PC V, AC full vented panels
  #3
Old 10-11-2018, 11:09 AM
Teth-Air's Avatar
Teth-Air Teth-Air is online now
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
If you don't weld them I wouldn't run them. Some look bad.
__________________
Home of the "Cordless Teth-Air" and NEW "Phantom Teth-Air"
http://www.sourceinnovations.ca
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
  #4
Old 10-11-2018, 11:24 AM
Yaeger34 Yaeger34 is offline
Currently: Not set.
Yaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond reputeYaeger34 has a reputation beyond repute
Default
I mean you already have them off the sled and even the skid apart. Try and find some used ones. I don't mess around with "fixes" like that when it could leave you stranded in the back country or even get hurt. And if you jump then a double no
The Following 2 Users Say Thank You to Yaeger34 For This Useful Post:
Frostbite (10-11-2018), Wheel House Motorsports (10-11-2018)
  #5
Old 10-11-2018, 11:30 AM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Cheap but risky option: Drill the crack tips. Weld the original cracks all the way along the sides to the top. Grind smooth on edges and weld in an aluminum stiffener. Monitor.
The problem with aluminum is that it fatigues and cracks at a relatively low number of stress cycles compared to other metals. And there is a weakened zone around the crack that is also susceptible to cracking given more cycles. So, the metal around that crack is not good. Welding will actually weaken the metal but will relieve the stresses in the metal around the crack. Hence you need to add fresh aluminum to spread the stress loading around the original crack.
But you have to consider that those rails probably have more fatigued zones that are getting ready to crack next. So, you might successfully patch these cracks only to move the stress adjacent to the reinforced/repaired area...and more cracks start there.
So, by repairing, you might just be moving the problem a few inches down the rail.
This is why they junk old aircraft airframes...aluminum fatigues fairly easily and quickly...and if one area fails...more are close.
Not what you want to hear...but you should try to find some low mile, used rails and replace both. If a rail breaks, you could cause way more, expensive damage or, worse, hurt yourself or someone else.
The Following 2 Users Say Thank You to jim For This Useful Post:
boondocker97 (10-11-2018), Wheel House Motorsports (10-11-2018)
  #6
Old 10-11-2018, 11:57 AM
Wheel House Motorsports's Avatar
Wheel House Motorsports Wheel House Motorsports is online now
Currently: is it winter yet?
Wheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond reputeWheel House Motorsports has a reputation beyond repute
Default
Aside from some eleaborate doubler plate. Like others have said, once they crack, its sort of a lost cause. the OEM cat rails are stupid weak to start so they flex a ton and crack like your seeing.
Highly recommend IceAge. Way better then stock. Or obviously look for some cheap takeoffs. Your already halfway there with the rails off the sled. Not worth putting it back together with those.
__________________
Wheelhousemotorsports@gmail.com
406-871-0955 Bozeman, MT
  #7
Old 10-11-2018, 03:09 PM
boondocker97 boondocker97 is online now
Currently: working for the man
boondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond reputeboondocker97 has a reputation beyond repute
Default
I agree fully with what Jim and Wheel House have said. Tried repairing a set on my M7 and they didn't last. Multiple spots started cracking later. Scrap them and find new ones.
__________________
Current Sleds:
2014-2018ish BDX Pro-Lite 900, 2005 M7 with upgrades - Ol' Reliable, 1974 Cheetah
Still in the Family:
2009 M1300, 2001 Mountain Cat 800 LE, 1972 Kitty Cat
Gone but not Forgotten:
1999 Powder Special 600 LE, 1998 Powder Special 600, 1993 EXT 550, 1980 JAG 340
  #8
Old 10-11-2018, 03:46 PM
Currently: Not set.
Basic Member
Default
Found new 2014 162" oem rails for good price. Is it bolt on into my 2013 162" M800 ?
  #9
Old 10-11-2018, 05:40 PM
Currently: Not set.
Basic Member
Default Does a 2014 162 M8000 Rail fit my 2013 162 M800 ?
On another note. Found new 2014 162" oem rails for good price. Is it bolt on into my 2013 162" M800 ?
  #10
Old 10-13-2018, 01:44 PM
Currently: Not set.
Basic Member
  #11
Old 10-13-2018, 08:37 PM
Cat00's Avatar
Cat00 Cat00 is online now
Currently: Not set.
Cat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond reputeCat00 has a reputation beyond repute
Click Here to Register
  #12
Old 10-16-2018, 06:13 PM
Currently: Not set.
Basic Member
  #13
Old 10-16-2018, 07:35 PM
Cat00's Avatar
Currently: Not set.
  #14
Old 10-17-2018, 03:51 AM
Currently: Not set.
Basic Member
  #15
Old 10-17-2018, 06:09 AM
Cat00's Avatar
Currently: Not set.
  #16
Old 10-17-2018, 12:01 PM
Currently: Not set.
Basic Member
  #17
Old 10-17-2018, 12:59 PM
  #18
Old 10-17-2018, 03:28 PM
Currently: Not set.
Basic Member
  #19
Old 10-17-2018, 05:19 PM
Cat00's Avatar
Currently: Not set.
  #20
Old 10-19-2018, 06:31 PM
Currently: Not set.
Basic Member
The Following User Says Thank You to Hjalti_GTO For This Useful Post:
summ8rmk (10-19-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Axys Hood w/Small Crack Thread Starter — wfieldin Forum — Hoods/Windshields/Belly Pans (Swapmeet) Replies — 3 Last Post — 01-22-2018 06:58 PM
Thread — Small crack in p85 stationary sheave Thread Starter — PurpleDragon Forum — Polaris: IQ Replies — 8 Last Post — 12-13-2016 08:25 PM
Thread — ported cylinders, found a small lil crack? ok to run? Thread Starter — Octanee Forum — Ski-Doo: TURBO Replies — 10 Last Post — 12-04-2012 07:04 PM
Thread — found a crack in my king cat rails Thread Starter — motocrazy2006 Forum — Arctic Cat: 1M Replies — 27 Last Post — 11-27-2011 01:04 PM
Thread — How to Fix a small crack in Sled Hood Thread Starter — SKS_guy Forum — General Snowmobiling Replies — 17 Last Post — 01-17-2008 03:58 PM
no new posts
