changes
About to pull the trigger on a '16 M8000. What do I need to know about the the Team clutches and what are some "must haves"? Likely gonna go with the MDS system but anything else a guy should look into? What about tools and alignment bars? Will most of the stuff I used on my '13 Cat clutches work on the Team clutching? Also do most guys stick with the 19/50 gearing?
Hears what I've done
Gripper skis
Canada sled parts steering bushing
21/49 gearing same 90 pitch chain, I also used a steel gear for the lower one. The 2017 models were geared to this ratio from the factory.
Vented side panels
Clutching: I have changed my primary spring to a 17 MC, I haven't rode it yet, I did try different secondary springs but didn't gain actually lost, going back to stock. There are many kits out there to choose from.
The 16 ltd works pretty good,I found shock set up is critical for both ride and performance. Your 13 alignment bar wont work, but the primary puller should I am sure some one will correct me if I am wrong.
