what are your thoughts on the recluse for the the snow. is it good are not worth having in the bike. I already have the kit in the bike but I was thinking of taking it out due to the amount of maintenance required.
Plus 1 on the radius x... Have it on my yz250x ... 35 hours on the bike zero adjustment... And man it locks up....I am plenty competent with the wheels on and manual clutch. I would not ride a snow bike without one. Radius x, get it!
the bike is a 16 yz450f. I have only rode it maybe 6 times and I didn't like the bike for the type of riding I do so its been sitting in my garage. seemed like after each ride the clutch was slipping to much and the free play gain was out of adjustment. on my yz 250 2st I don't have this problem, clutch usually last about 3 to 4 rides before needing adjustment. seems like the snow might be easier on the clutch due to the fact that your always wide open and the clutch is fully locked.
Sounds like you have something else going on. A stock YZ clutch is pretty dang tough and will take some serious work before it needs adjustments. THey will obviously heat soak and fade some if your abusing it like nuts on single track but ive put 100+ hours on stock clutches in snow and dirt without issues.the bike is a 16 yz450f. I have only rode it maybe 6 times and I didn't like the bike for the type of riding I do so its been sitting in my garage. seemed like after each ride the clutch was slipping to much and the free play gain was out of adjustment. on my yz 250 2st I don't have this problem, clutch usually last about 3 to 4 rides before needing adjustment. seems like the snow might be easier on the clutch due to the fact that your always wide open and the clutch is fully locked.
It's not a set up issue it's a rider issue. Most of my riding on dirt is in some extreme trails.
For sure it is an either like it or not... The more track you like the less you like it to me...We seem to be getting a little off topic. I'm thinking I will leave it in and see how it works out for me. Sounds like some like it and some dont.
