I have a 2015 800 Proclimb that starts just fine when cold. However, when warm and after a short break, more times than not, it will fire right up and immediately die with the speedometer needle staying in the pegged position. Then for about 2-3 minutes you can pull all you want, it's not going to start. Then after about 3-4 minutes, it will fire up like nothing happened and run just fine. Now, every time our group stops everyone else in the group has to wait to see if my sled will start and stay running. It's embarrassing.
I have tried insulating my fuel lines (they are all wrapped in heat wrap). I also added a heat shield between the Y pipe and the fuel injectors thinking maybe I had a vapor lock scenario going on, and it doesn't seem to help. I changed the plugs, I have even tried a brand new ECU and it does the same thing.
So, I am thinking it could be a throttle safety switch but, what would that have to do with my 2-3 minute wait? It could be a plugged tank vent, maybe? How do I check that? What am I missing?
Any help you could provide would be appreciated.
