Did anyone who has received their axys with the digital gauge have a battery or not. I read the manual and it said it would. Just wondering if it does or not. Thanks
The sled will come with a battery if you checked it with electric start but not if you only checked it with the GPS gauge.
Hopefully they sent along the jumper harness for those equipped with estart. This way you can just plug that jumper into the sled and then hook it to a battery in your garage to update or use the gauge without having the sled running.
Would not that work by turning the key to the run position?
S/C
Yep! Going to have to hook a battery up just for it!
What I meant to say the first time:
Hopefully they sent along the electric start jumper harness for those without estart. This way you can just plug that jumper into the sled and then hook it to a battery in your garage to update or use the gauge without having the sled running. This is what I do on my PRO that I added the gauge to.
Prayn4snow;3851182 I would think they have some lite weight battery out now that fit this sled over the stock one?[/QUOTE said:I have been running these light weight lithium batteries in my 14 & 15 pros with ES- work great-take up so much less room I generally cut the tray down and have nore room for the QD belt.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0CFgQtwIwA2oVChMI79CL_fvexwIVhhGSCh0YAgE9&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DrVwVsVJNaKk&usg=AFQjCNFbibhA4yTfRcbpEuQSJw9Ko5GEww&sig2=3GNhYQTd13k7_z5YUFTyYg
Why did you choose the one you did? They have smaller ones for $68, all I want is for the display when engine isn't running. Do I really need a bigger one or did you do it for e-start or to fit the battery box?
