A
Cats web sight shows this sled with standard electric start. If so thats alot of weight you could remove right there, if possible. Is there any way around this electric start.
Note: this_feature_currently_may_not_be_available_in_some_browsers
that would be correct. street bikes, yamaha snowmobiles... they all have high compression and you are not able to turn the thing over besides an electric starter.I doubt you could pull start a 4 stroke sled with a recoil...most likely yank your arm off...as far as I know of..all 4 strokes are e-start only..no recoil on them....I suppose you could do a hand crank the way they used to do cars years ago.....(J/K).......
well doubt away its your right but have seen it done when starter failed Out side in the snow and chit :tsk:
