Looking to do 09 front end or newer,skinz ftont bumper,got to do somthing with the running board, and also saw a 05 with newer style seat on it.
1~ i am worried if i take coolant out of s already small system how will it run (i ride east ccoast)
Can i add coolers some where else?
2~ does the newer style seat bolt right on or do you need the newer tank too?
3~ do thet still make the front fender update kit a dealer?
Any and all help thank you
Also will a 09 tunnel fit on this bulk head?
the rest has been answered above here by 94! so I will just attack the tunnel question..
-yes and no...if your good at modding and knw what your doing and can make some customs adjustments to the attachment and brackets, sure you can get the tunnel attached to a 900 bulkhead, but then you will have to work the coolant llines, ecu and ALL electronics and re-route them somewhere else, change fuel tanks (and pump depending on 900 yr) and also work the chassis hoop, console and plastics..
but if your motivated and wanna do it, screw it do it man...I am ALL about making my own "look", I like the challenge and I like to share what I make...but if your not sure, I wouldn't even attempt it...its not for the faint..
Thanks guys ..... to be honest i think i am going to look for a 09 dragon rear cooler....runs the whole tunnel
you will have to attack the fuel tank, (possible pump as well) coolant hoses, routing system and the electronics that connect and mount in the SAME spot the coolant hoses would attach to the cooler (in front of tank)...but just like my comment above...your call
Also will 2012 a arms fit in my sled? I want to use 09 spindles. Also if arms do fit can i use the ball joints off my stock 05 arms ?
yes ALL Polaris a-arm from 05-2013 will attach to the 900, I would change spindles like you stated for sure...all hardware will work as well. just depends if you wanna use the newer style sway bars (which are GREAT, but you must use the 09-up narrow front end plastics to use the sway bar)
Didn't someone have a front bumper for the IQs that you didn't have to remove the rad?
I am pretty sure that the TreeDog bumper would work for this, it mounts up above the cooler, but if you were decent at modding, you could make them both work im sure, but I am not a fan of the wide front end, keeping plastic bumper and attaching another bumper above it (looks too fat and weird IMO) and I also am not a fan of the radiator (here we go, lol)..its a dead useless system that does nothing...no matter how you route it..use scratchers all the time, and maybe keep all your bogies so you can foucs on cooling the cooler in the rear and not the hyfax as well.
just my .02 buddy, but to each his own...you will only learn by trail and error, and that's how I learned
