silber problem DET
Boston Racing
1,628
Colorado Springs, CO
Also the the mag side powervalve bolts and see if they are hitting the pipe.
What lights are displayed on the box when the problem happens?
Boston Racing
1,628
It is important that the red and blue lights display when any pressure is built. Do you have the solenoid installed so that the side with 2 ports faces the throttlebody?
2007dragonman
740
85
South dakota
sled
noper the bd was just part of breaking in and would only do it when you were under throttle really hard just came back into town and it runs awesome after some time, i kinda looked at the silber one tonite and its odd , can barely get into the throttle and his the det. its not even rideable, not sure what to look at next
tdorval
1,201
276
Red Lodge, MT
Out of curiosities sake what happens if both red and blue lights aren't displaying under pressure? The remedy if this actually is the issue?
I'm fairly sure both of mine are lighting, but its nice to know as much as possible about these things!
Boston Racing
1,628
It means that there is a problem. This is the mode the controller should go into when under boost. If it doesn't not make sure the solenoid is facing the right direction and the lines are good to the controller.
tdorval
1,201
276
Red Lodge, MT
Ok cool, I thought I had remembered seeing green blue under light boost thats why I was a little worried.
Good info, now need some serious snow!!!
L
lightening800
1,381
167
northern alberta
mine did the exact same thing, my tps had moisture in it causing all kinds of goofy readings, toof it out blew it out and illed it with dielectric grease and no more det light, but i have a blue/green light coming on at idle causing the plugh to foul once in a while, crap boxes!!
crackerjack
36
48
I had the same Blue/Green at idle and silber got me a new box. It fixed it and the low end is alot better also. The part of the box that senses boost is not functioning right. Call Justin. :face-icon-small-win
2007dragonman
740
85
South dakota
update
put in 3 gals of race gas and works awesome now just a little to rich on low end, our control box is going bad so i did not change numbers, Thanks everyone
