Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 05-19-2019, 11:24 PM
donbrown's Avatar
donbrown donbrown is online now
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
Default 2020 new spindles information
2020 Spindles and Rubber Stop come as a package and are avaialbe in the 2020 catelog to order, there are two tabs on previous model 2017-18-19 skis that you will have to shave down to make the 2020 spindle fit in, it is easy.
What are the part numbers?
__________________
www.CNSA.NET lifetime member
Rate this post: Yes | No
The Following 2 Users Say Thank You to donbrown For This Useful Post:
Daag44 (05-20-2019), SNOBI-WAN-KENOBI (05-20-2019)
  #2
Old 05-21-2019, 12:04 PM
SNOBI-WAN-KENOBI's Avatar
SNOBI-WAN-KENOBI SNOBI-WAN-KENOBI is offline
Currently: Not set.
SNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond reputeSNOBI-WAN-KENOBI has a reputation beyond repute
Default
Does the kit show you where to shave down the skis? Thanks
Sent from my SM-G965U using Tapatalk
__________________
WSSA MEMBER
  #3
Old 05-22-2019, 12:58 AM
donbrown's Avatar
Default
NEW DEEP SNOW LIGHTWEIGHT SKI SPINDLE KIT* • Improves front dynamics when sidehilling.
• 400 g lighter than stock spindle.
• Standard on Summit X with Expert package.
REV Gen4 Backcountry, Freeride, Summit and Expedition 860201976
$219.99
860201976
__________________
  #4
Old 05-24-2019, 06:41 PM
NHRoadking's Avatar
NHRoadking NHRoadking is online now
Currently: Wanting more snow
NHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond reputeNHRoadking has a reputation beyond repute
Default
From a 2020 Expert test rider in Snowtech Magazine:
These front suspension changes are easily as impressive as the rear. We found the front end doesn’t dance around nearly as much as it used to. You can put it on an aggressive sidehill with tracks under the snow, and when you cross those tracks, the front end doesn’t give you the negative feedback that Ski-Doo is so infamous for. Instead, it stays straight and true giving you more confidence in the line you have chosen. On the trail, the front suspension and handling is substantially better. This sled feels more like an MXZ on the trail. It corners extremely flat and is very predictable. We think the new shocks with Kashima coating has helped this a bunch. Also, the new ski rubber and spindle are a plus here.
  #5
Old 05-26-2019, 09:50 AM
MKULTRA MKULTRA is offline
Currently: braaapping
MKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond reputeMKULTRA has a reputation beyond repute
Default
sounds like a sale pitch
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to MKULTRA For This Useful Post:
LPIdaho (06-06-2019)
  #6
Old 05-26-2019, 11:21 AM
NHRoadking's Avatar
Default
Quote:
Tough to find a review that isn't.
I'll see for myself if the new spindles, stoppers and skis make a difference when the 2020 arrives.
  #7
Old 05-26-2019, 06:10 PM
Big10inch Big10inch is offline
Currently: Still Riding...
Basic Member
Big10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond reputeBig10inch has a reputation beyond repute
Default
What changed on the skid? No coil over or air shock, no 15" stiff track, still has t-motion?
  #8
Old 05-27-2019, 07:40 AM
NHRoadking's Avatar
Default
Quote:
Nothing was announced for changes to the skid.
I believe the announced changes for 2020's mountain sleds are:
Running boards;
Spindles, ski stoppers and skis (for the Expert and Freeride); and
Shorter tunnel and new shocks (Expert only).
  #9
Old 05-31-2019, 08:15 AM
Mjunkie's Avatar
Mjunkie Mjunkie is offline
Currently: Working to save $$$
Mjunkie has a reputation beyond reputeMjunkie has a reputation beyond reputeMjunkie has a reputation beyond reputeMjunkie has a reputation beyond reputeMjunkie has a reputation beyond reputeMjunkie has a reputation beyond reputeMjunkie has a reputation beyond reputeMjunkie has a reputation beyond reputeMjunkie has a reputation beyond reputeMjunkie has a reputation beyond reputeMjunkie has a reputation beyond repute
Default
Running boards;
I think they did some change to the primary as well but this will be my first doo so I'm in learning mode.
__________________
Riding soon:
2020 Freeride 146
Currently selling:
Arctic M parts
  #10
Old 05-31-2019, 06:18 PM
NHRoadking's Avatar
Default
Quote:
Doo you know what they might have done?
  #11
Old 06-01-2019, 05:15 AM
Mjunkie's Avatar
Click Here to Register
  #12
Old 06-01-2019, 12:17 PM
Motorbreath_ Motorbreath_ is offline
Currently: You have reached thelimit of your Free BasicMember readingprivileges.
Basic Member
Motorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond repute
The Following User Says Thank You to Motorbreath_ For This Useful Post:
Mjunkie (06-01-2019)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2020 Ski-Doo Summit X with Extra Package Spindles and Ski-Stop Thread Starter — Norona Forum — Ski-Doo: REV Gen 4 Replies — 4 Last Post — 05-20-2019 06:07 PM
Thread — 2020 Spindles and Ski chat... Thread Starter — Ace Freely Forum — Ski-Doo: REV Gen 4 Replies — 5 Last Post — 03-29-2019 12:41 PM
Thread — 2020 Thread Starter — pauly815 Forum — Ski-Doo: REV Gen 4 Replies — 18 Last Post — 01-09-2019 06:31 AM
Thread — Zbroz spindles arsfx spindles polaris dragon/pro Thread Starter — Polaris pride Forum — Suspension/Shocks (Swapmeet) Replies — 6 Last Post — 04-26-2013 12:16 PM
Thread — HRP easy steer spindles ,or 08 Iq spindles? Thread Starter — alsled Forum — Polaris Replies — 2 Last Post — 02-18-2009 10:21 AM
no new posts
