I'm Going to a Challenger Extreme 2.5 x 174 from a 163, what Rail extentions have people used???? How about Tunnel extentions???? Gonna throw on a big wheel kit too. Thanks!
I have been thinking about the same swap... but will it be a dead dog with only the stock power turning it?
We got everything from Avid for the 174-2.5" last year, this year we did the 3" paddle and did a longer extension, Iceage rails and extended the cooler (thanks Fastrax!). All worked well. I would avoid the bigwheels, more leverage on the bearings, less track on the ground and they will almost certainly hit the tunnel with the taller lugs. You will be impressed!! :face-icon-small-hap
With a little clutching and maybe some gearing it will turn it just fine. Brew can help you out with that.
I've been running a 174 2.5 for a year now and it works great. Rooster built clutching, 20/51 gearing, sop pipe and head. It climbs great and in the woods works even better.
I got a pretty good handle on what i need, should be a pretty sweet ride when i'm done, gonna do some powder coating while i have it apart, and throw in a head and slp y-pipe and pipe, i'll post some pic's as the project progresses, but SHHHHHH don't tell the rest of my buddies, i plan on keeping it a surprise! :face-icon-small-win
For you who have done the swap, does it hurt your maneverabilty at all?
If you are used to a 163 you will notice little to no difference in handling. You will however notice a huge difference in deep snow performance:face-icon-small-hap
I found this to be not true as i went from 163 to 174 and you know the extra track is back there.
Take a pull with mine up a hill and through the trees and then take a 163 and quite abite different.
Just my findings and as you say great in the deep snow and would not do back to 163 x 2.5 but would like to try the 163 x 3 to see the difference for myself and this is doing to happen this year as buddy is installing the drop and roll and 3 x 163.
