Upgrade to Premium
General Snowmobiling Snowmobile related topics only
Reply
  #1
Old 10-15-2008, 10:40 AM
team2 team2 is offline
Currently: Not set.
Basic Member
team2 team2 team2 team2 team2 team2 team2 team2 team2 team2 team2
Default Fox Shock Tuning Tips
If you currently own or are thinking about owning, know that there is now an online chart available to view where your baseline settings should be for Float 2's, EVOL R and EVOL X's as well as the Evolution Rear Suspension.
Tom's Snowmobile has put up this chart for you guys to check out.
Check it out here: http://media.50below.com//organizati...gs%20Chart.pdf
Rate this post: Yes | No
The Following 3 Users Say Thank You to team2 For This Useful Post:
donbrown (12-25-2018), mtnxtreme1 (12-24-2018), NapaMatt (02-19-2010)
  #2
Old 12-27-2018, 01:15 AM
donbrown's Avatar
donbrown donbrown is online now
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
Default
ttt
__________________
www.CNSA.NET lifetime member
  #3
Old 12-27-2018, 07:34 AM
skidooboy's Avatar
skidooboy skidooboy is online now
Currently: titanium plate tester
skidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond reputeskidooboy has a reputation beyond repute
Default
another racer tip is to, put zipties around the lower shock tubes, and monitor the suspension travel. you should feel the sled bottom every once in a while, not on every bump.
you should use almost all of the travel or they can be a harsh ride (floats/air shocks).
once you get where you like it, and you have found your sweet spot, make a mental note where the tie rides, and then the ties help you monitor the travel usage, for future settings changes, to help you get your settings back to your baseline. ski
riding northern ontario's back country
  #4
Old 01-11-2019, 01:31 AM
MrIQR MrIQR is online now
Currently: Too many sleds, not enough time
Basic Member
MrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond reputeMrIQR has a reputation beyond repute
Default
Use a o-ring instead of a zip ty
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
