I have a '14 pro 163" with burandt evol shocks all the way around, alt imp 36" arms. my concern is that when the sled is on flat ground, only the last 1/4 of the rear suspension touches the ground. the front of the track is off the ground a good inch or two and than tapers down until roughly the rear arm location. is this how the stock 163" is or does the 36" raise the front end causing the front of the rear suspension to lift as well? just curious if dropping the front arm to the assault location would help this or if this is a normal thing.
