K
Who is running this vest and how do you like it? Any problems with them?
Sent from my iPad using Tapatalk HD
I am interested in checking out this vest. how could I try one on and see how it fits?
I have had the Wary Impact vest for a year now. The Impact is the one with the chest protector, but I don't see it in the lineup for 2013. I am 5'11" 175, the medium size I ordered is real snug with all my gear on. If I had the chance I would try them on before you order unlike I did.
Good spot for the shovel handle outside the bag, but the shovel blade is inside the main storage area and there isn't much room in there after that.
I like that the deployment handle is small in size so it doesn't get caught on anything, but big enough that it would be easy to find and pull if ever need be. Since the impact vest is a little more sturdy I find my lower back didn't hurt as bad after riding either.
Also make sure you wear the under-leg strap. I just took the adjuster off the strap to make it as long as I can, but it still will only allow the vest to lift up about 2 inches.
I heard the vest soaks up water and gets heavy. Is that true?
For 2013 it's called the AviVest. There is a an external shovel blade pocket your can buy on the Wary website for $20.
An old thread but I stumbled across it and thought i would add my .02.
All in all it is awesome. It distributes weight well and takes the load off or your shoulders. The front pockets are great. You have enough room for radio, gps, beacon (if you choose to keep it in vest), Leatherman and room to
