i just started working with an '01 151-highmark chassis for a boondocking mod
(....unfortunately i don't have any pictures for the skid set back yet
)but i can tell you some things i have noticed while doing the drop and roll in it
.the goofy factory track has shorter paddles down the center in a vain attempt to help tunnel "clean-out" (with the so called 2" track there is only a 1/4" of clearance at the front of the cooler on top of the tunnel
)so dropping the skid really could help in this area
.the front tunnel/bulkhead cooler also has @ 1/4-3/8" of clearance as well in places(hence the reasoning for a d & r :beer;
:beer
if you're happy with the 2" track you should think about a d & r plus the drop and pull back of your skid. you could check where your rear axle/skidframe/track relate to each other and compare the "safe" distances you can relocate the front and rear mount points in the factory hardware...if not you could go to 7 tooth 3" pitch drivers and run a new/lighter 2" track-you'll gain a 1/4" of clearance up in the bulkhead area plus lose rotating mass
D-H.P!) plus if ya get something longer (153"-159") you can really pull chit back!(just don"t get crazy or you'll need anti-stabs!)
