B
lNICE: Skidoo Package: 2001 SUMMIT 600 141" & 1999 440 MXZ-X MOD. ($3800 takes both!)
2001 Skidoo Summit 600 144" & 1999 Skidoo MXZ_X 440
Hello I am offering a package deal here: I have a Mint;2001 Summit 600 144" track w/aftermarkets & 1999 440 MXZ-X series race sled thats been modified and trail converted w/tons of aftermarkets.
$3800 Takes BOTH SLEDS Today!
SPECS Skidoo 440 MXZ-X:
440cc Ported and Polished - Liquid Cooled Motor
Low compression domes and head installed to run reg.pump fuel.
Gutted Exhaust Can
Kinetic Machined, Balanced Team Primary Clutch
Kinetic Race Secondary Roller Clutch
GP Racing Rear Suspension - rebuilt rears in 2005
Pro Taper 3" Riser
Answer Alumilite2 Handlebars
Power Madd Hand Guards
Steel extended Brake Line
Rear Drag Wheel Blocks on rails
Running Board traction/strengthen boards
Hole Shot Skid Plate
Cobra Windshield - low
Stripped of all graphics
Hand Warmers
Primer Starter System
Original Cover
Condition: Good
X-series sleds don't have Speedo, only Tachometer. So no Odometer, however I would guess around 1500 miles no more then 2000 miles.(our 600 is rode more and has only 3100 miles currently) This sled has been only rid'n a couple times a year the past two years!
Small Belly pan crack - brake side - not seen unless hood open/clutch guard off
Small ding on trailing arm - throttle side, seen in photos. It is from another sled ski hitting it and is just on the flat surface area so it has not weakened the arm. rode like that the past couple years
This sled Rips and will have people scratching there heads for a 440cc sled!
SPECS: Skidoo Summit 600 141"
Black Color - rare/hard to find
600cc sled - Strong good running motor/ no problems - Pull & Go Sled.
141" track - Great condition no missing lugs/no fraying on track
4" Bar Riser & Bar Pad mounted
Power Madd Hand Guards/Black
Drilled Running Boards/ less snow build up
Aluminum Gas/Cooler Rack on Tunnel
Hole Shot Skid Plate - Yellow
Dyno Port Race Pipe - runs crisper w/better throttle response then stock
Cobra Carbon Fiber LOW Windscreen
Front Shock Skinz - Black
Spare Parts List: OEM Pipe, Spare Belt, Brand New Full Length cover - over skis to rear of sled/trailerable!, OEM high clear windsheild, Titanium TRA arms, whatever other skidoo things I find laying around in the garage.
CONDITION:EXCELLENT
only 3k miles Nothing broken, cracked, missing, etc. The sled has been maintained and serviced every ride, stored in garage or enclosed trailer year round. It is my wifes sled and she's upgrading to a new Polaris IQ Chasis.
If your in the market for a sled or set of sleds this is the best deal anywhere. ZX chasis skidoo's are the most dependable and most aggressive sleds made and if it wasn't for changing to the IQ Polaris I had builT by Carl's in Boise this fall, I would not be selling these sleds. So take advantage of my loss of $-invested and your gain in a great set of toys.
So be the First to PM or Email:buckyshoemaker@yahoo.com and buy BOTH SLEDS for: $3800 (thats the price of one fairly good condition sleds)
Gutted Exhaust Can
Pro Taper 3" Riser
Hand Warmers
Original Cover
Condition: Good
CONDITION:EXCELLENT
