2006 M7 with Speedwerx 800BB, speedwerx single pipe and can, sno-pro intake, oil delete, Digitron EGTs and speedwerx reprogrammed ecu. PTO piston burned down in about 200 miles after build. I had checked wash (through the exhaust valve slot, maybe misleading view angle?) and plugs the first couple rides out and wash and plugs looked good (I am new at this so maybe I was misreading) with a max EGT of about 1150 (probe is 4" from piston skirt).
Sled ran great, which is what I understand they often do before burning down from too lean. EGTs the day it burned down were actually reading cooler on the PTO side so I suspected something was wrong but didn't think I was in danger of a burn down because it was running cooler, obviously I was wrong.
Can someone tell me by looking at the pictures was this burn down from too lean, detonation (bad gas?), or something else I'm not seeing.
Thanks,
Garrett
Thanks,
Garrett
