P
ridin an 09 m8 with boondocker pump gas kit. after a good pull the sled wont start sometimes unless i let it sit for like 10 or 15 miniutes. whats that about, very annoying
The temp sensor in these motors is in the case, in the water pump passage. The hot water exits the bottom of the motor, not through the head like many older pol and cat motors. The temp sensor has 2 yellow wires going to it(runs down by the recoil rope). you can put a switch in the circuit so when the senor is tripped, due to excessive heat soak, you can flip it and will be able to start the sled. then flip the switch back and the sled will run fine because it will be pumping fluid again while running.
adam is right.if you let it idle down and turn off the sled and the switch.when starting i alway start with the switch off and the wrench well show on the display , this wel over fuel the motor then turn the switch on the wrenh well go away and the sled wel idle smooth.the problem is heat soak and the fact all thr kits use the lines that are on the throtle bodies.and this is looped from the water pump to the turbo then back to the pump area were the sensor.if it won,t start hold it pinned. i'm going to try somthing .send the hotside line to the res.like the line off the head .this should work.The temp sensor in these motors is in the case, in the water pump passage. The hot water exits the bottom of the motor, not through the head like many older pol and cat motors. The temp sensor has 2 yellow wires going to it(runs down by the recoil rope). you can put a switch in the circuit so when the senor is tripped, due to excessive heat soak, you can flip it and will be able to start the sled. then flip the switch back and the sled will run fine because it will be pumping fluid again while running. It is also important to let the sled idle down before shutting down so it doesn't leave extra fuel in the motor when the ignition is killed. a combo of these things should cure your problem.
Adam
I like the idea of sending it back to the reservoir to avoid this problem. I assume you propose to just put a plug in the other return line that goes to the pump area? Hmmm.
