Primary spring
Csellors
New member
24
2
3
Hi all. I have the gold spring in for low elevation and I believe it should be a 120/320 at 6-8,000 feet. Problem is that the dealers on the flatlands don’t seem to have them in stock. I have ordered one but it may not get here before we leave. Will a 120/310 work? They have that one in stock
Thanks
RMK-King
Super-Moderator
Dec 25, 2007
1,928
1,374
North Dakota
It will work fine, your peak RPMs will drop around 100RPMs so you might have to make a slight weight adjustment.
Csellors
New member
24
2
3
Hey. I have 10-64 in for 6-8 k. I also have an slp blue pink 140/340. Would that work? Thanks in advance
gtwitch
394
201
Laramie, Wyoming
I am running the Blue-Pink with 63g lightning at 10K altitude but have pipe and heads on mine SLP stage 3 so I think your weights and a Blue Pink at your elevation might be a good start.
gtwitch in wyoming
Scott
Scott Stiegler
69,618
11,737
W Mont
I've been running gold primary with 62g Belly Busters (who makes that gold primary spring.... And is it called yellow or gold?)
Black/purple secondary with 2 delrins.
HM Turbos secret helix (I honestly don't know what it is).
5-8500 feet.
I used to have the blue/pink primary, but Hart reclutched me a couple years ago and put that gold in.
I had to replace my primary last month (they transferred the same gold spring and the in some matched Polaris 10-62s. Suddenly now I am only turning 7950 on a pull.
I'm thinking of refreshing the clutching....and going back to the blue/pink primary and keeping the blue/purple secondary.
Thoughts?
RMK-King
Super-Moderator
Dec 25, 2007
1,928
1,374
North Dakota
5-8500 feet.
Thoughts?
The Polaris gold is a 100-275,if thats the gold that you are running then the blue/pink will defiantly get your rpms back up.
