F
Been checking pdrive on the hill at 6500’, was surprised to see I’m running to top of primary, basically out of gear and maxed top end speed..50mph
maybe why I am seeing surging rpm from 8-8200rpm on gauge
did a long 100second wot pull and seen primary temps hit over 104c/225f on top of primary were belt was running.. I think this sled from past exsperince should be geard up at least one tooth on top sprocket..
Sled is completely stock with 3 percent breakin left, have 2.5 grams added to pivot bolt since 50percent breakin..
Called Joey tonight and problem solved, here was his reply..
Had a good conversation with Joey from I backshift, he's one of the best if not the best with brp clutching.. Before I was into describing my problem More than a minute he already new of the problem, it's charterisics and what was needed to fix problem, he sure is welcome to share his wisdom on here, he says he has lots of good info on his website blog under G4 pdrive, he is running hard getting kits that work out the door, and this G4 is keeping him real busy..
first off stock gearing is good for 76mph on a 1 to 1 ratio which is more than needed for the G4 175.. This is almost good enough for turbo sleds if the rest is fixed correctly!!
he says if I'm only seeing 50mph on a hard pull and gearing is good for 76mph and belt is top in primary, it's very easy to find out what's wrong.. Had to think about it for a bit and it came to me..
belt has has to be slipping in secondary at bottom of sheives with least side surface area it's running on.. He's been seeing this lots and there is only two remedies.. First is to go to less helix for slower up shift or increase secondary belt spring tension with stiffer spring.. He highly recommends the latter one.. With so much snow load for mountain riding, large tracks and a strong motor, the secondary needs lots of squease to prevent slipping and heating of clutches and belt..
another gain of more squease will be that belt will now be able to run not as far up primary and not as far down secondary utilizing more surface area and allowing for a much cooler belt, less pealing of belt on cooling fins
he had me look at the lower secondary sheives and he was exactly correct, with heavy rubber deposits from belt slipping and above a dark shoe polish finish where it had extra heat added.. He said guys are reporting over 300f and belts don't last long, last year on 17s there was no cooling fins on secondary and this just happened that much quicker than this year..
he says many guys are telling you to drop secondary spring pressure and this just makes problem worse, or add more pin weight and this just makes it happen quicker.. Problem stands with secondary spring..
also has found problems with primary springs and that's a entire another issue to deal with latter, he's working on some ramps for turbo sleds and hoped to get them out soon
once again thank you Joey and can't wait for your arms.. Problem solved, and no need to gear up
