BULLSH** POLARIS (ELECTRIC RELAYS IN HARNESS GO BAD FROM WATER INTRUSION)
5.00 star(s)
sledheadd
1,621
372
83
too far from mountains Alberta Canada
depending on the connector...Dielectric grease can cause issues of it's own... for the most part... it is good to use.... there are also different dielectric greases.
A non-sealed relay (the actual case of the relay.... not the connector)... is not good at all, if truly not sealed. A non sealed relay... even in a 'bag' with the electrical stuff... IMO... is just waiting to fail from all of the humidity and condensation that happens in these sleds from normal use.
Thats why I'd like to see some high resolution photos of the relay itself and it's markings... also to know the resistance of the stock relay between post 85 & 86.
As for the relay and ordering.... need to match, fairly closely, the resistance of the trigger coil in the relay.
As for the engineers on these sleds at Polaris... I've met them and know a few of them... they are not 'corner cutters'.... that is where production costs and the staff at Medina get in there... and reign-in the engineers and their abilities to make a great sled and fix what really is a 'fixable' issue of the sub par wiring and component integration, IMO, on these sleds.
Plasti dip or brush on electrical tape will make them water proof. It's not the cure but it is a long lasting fix
Sage Crusher
3,268
1,196
Rock Springs,Wyoming
FWIW-There is another relay for those of us with electric start��
It is located on the harness leading to the battery zip tied to the brace over the footwell
mountainhorse
18,606
11,814
West Coast
www.laketahoeconcours.com
Factory uses Song Chuan 871-1C-S-R1 relay (shown in photo above)
Looks like it is a 35 amp relay. 104Ω resistance on the coil overall, including resistor.
871 -- Basic series designation
1C -- Single pole double throw
S -- Sealed type washable
R1 -- Coil parallel with 1/2W resistor, 12V 680Ω
Mouser shows these for $2.61 each
http://www.mouser.com/ProductDetail/Song-Chuan/871-1C-S-R1-12VDC/?qs=X4N6sOTYzkiqzyaIQ7onUQ==
Hope some electrical guru's on here can assit in choosing the correct relay's to purchase-to at least give this a try and maybe cure the issues.
attachment.php
06redrevx
550
242
I have been really surprised that nobody has come out with an aftermarket complete wiring harness to replace the Chinese junk that we are provided with. Somebody would do very very well with this if done correctly.
Aftermarket guys are you listening? And Polaris are you listening!!!??
mountainhorse
18,606
11,814
West Coast
mountainhorse
18,606
11,814
West Coast
Unfortunately... It's a numbers game. No need to improve if the number of warranty claims is below a certain threshold that their corporate division sets... for PI corporate.
Sage Crusher
3,268
1,196
At those prices... buy 2 of them and keep them in a zip lock for you and your friends!!
Polaris wants $26.95 ea
MH- You sure that those will work for our application? If so I am buying a few dozen- !!!!
The female mating part I feel also allows moisture to breed as it is not sealed at all and water is pooled on the resistor and starts germinating the ugly " greenies"
GreenState
427
233
McCall
Before my sled was on snow this year I relocated the relays. Polaris should have done this, but they didn't. Take the 5 minutes to do it and you'll save yourself a lot of trouble.
Pop the hood, cut the zip tie that holds the air box to the over-structure, add a little di-electric grease to the relays, wrap them in electrical tape, and find a longer zip tie to replace the one you cut. Done.
mountainhorse
18,606
11,814
West Coast
It is the same number as on the case photo from Sage above.
I meant to say "buy 20"... ;)
http://www.mouser.com/search/ProductDetail.aspx?R=0virtualkey0virtualkey871-1C-S-R1-12VDC
mountainhorse
18,606
11,814
West Coast
If it were me, on my sled... and I wasn't worried about the warranty... I'd install some of the better quality Bosch fully sealed relays with silicone sealed connectors...
But hey... that may be a bit overboard.
2XM3
3,280
1,370
Bitteroot valley,MT
Yea...The relay integration in the harness is VERY "Bush-League" at best...
For the foul conditions that these sleds see... a MUCH better relay and connector should be used.
SHEESH !!!
yup, amazing really...need to be fully sealed weathertite relays, its pretty amazing they do the things they do
Sage Crusher
3,268
1,196
Sage Crusher... Can you pull one of the relays and take a photo of the bottom, connection side, of the relay... I'd like to see how Song Chuan seals them.
Here ya go-
I honestly feel that it is the female (connection) side that gives us fits. It is not sealed where the wires run through it and water travels down those wires and pools on the sealed portion of the relay, and grows the "greenies"
Below is one of the female end with gunk and then w/ relay all cleaned up.
AKFULLTHROTTLE
1,986
1,146
Alaska
For the GPS model I ziptied to the holder which is near where you did yours. Also greased and sealed with some special tape.
CO 2.0
2,994
Fort Collins, CO
I've popped 2 of those relays by the post now. I have since wrapped them in that stretchy silicone tape and pretty much sealed them up completely. No issues since. And FYI those things can be bought online for about 90% cheaper than Polaris sells them for. Same exact relay from the same manufacture. I bought like 8 of them just to have if I need them. At $2-3 a pop, it's no biggie
