B
MTN MONSTER MOD - Carl's 975 BB w/210HP - MOD 900 Polaris w/166" track-30hp N20 $5750
05 IQ POLARIS RMK 900 166" W/CARLS CYCLE 975 BB KIT
1643 original miles - 975 kit installed @ 600miles.
Updates Completed
Estimated Sled weight: 490lbs with aftermarkets and diet, hood weighs 6lbs now, pipe/can -20lbs, airbox -10lbs, plus additional oem loss
Over 14k Build!
Crank bearing update when 975 installed
Ran 2 belts in past two years - 1080's
New hyfax - Installed begining of season
New intake boots - When V-III's replaced @ start of season
Not one broke or cracked part - if it broke i replaced it, very clean machine!
---MODS---
180 HP 975 Big Bore: 30hp Boss Noss - Just installed last week (210hp on the button)
166 x 2.4 track
FOX Reservoir Rear shock w/Fox Float Front Skid - revalved this spring
8" Billet 2-Wheel Mountain Kit
SLP Pipe/Can
Tricity Performance Airbox w/dual induction setup (pulls from front bellypan; inside belly pan from shock towers & under rear bellypan)
5 SLP disc Vents for dual induction air box - no bogging w/max air flow all the time!
Radiator Delete Kit
Tri City Aluminum Clutch Cover
Goldfinger Lefty
Holtz Scratchers
SLP torq Arm
SLP push arm
High-Strength Recoil Rope - w/bottom bolt left out to enable rope replacement in future w/out pulling motor mounts
SLP - (SLT) Straight Line Tracking Ski's -black w/blue loops
2-Cool Side Panel Vents w/custom 975 logo's and clutch side prefilter - installed last year
2-Cool Pillow Vents - installed last year
F-Bomb Racing Snoweliminators - installed last year
Custom 6" flyscreen - installed two weeks ago
3" Bar Riser
BOSS TFI Controller - installed last year
V-Force III REEDs - replaced this season
Hole Shot Black Float Plate
MTN Fit - Headlight Delete Kit (shaved 7lbs)
Xteme Toyz Custom Made Hood Vent Kit - lifetime warranty/replacement goes with sled! (lost one boondocking and they replaced it)
EXTRAS: OEM Polaris Cover, xtra clutch spring, Gallon of Redline Oil and anything else i have in the garage.
Selling 2 Go Supercharged 4-Stroke Period:
Hopefully wont regret it, cause believe me when I say this sled is dialed and pulls like a freight train. Smokes most any 2-stroke mods out there w/out N20 be insane with it! Basically got N20 for steep long pulls in elevation-all ready to go just need to fill bottle. Sled loves the powder and will amaze you I promise. I have blown 2 belts in two years and the one this year was due to making a long climb while jumping a gap in the climb. Blew the belt upon landing @ WOT. (my fault, didnt see the gap til 2-late?) No Vibration like most other 900's and believe me I've rode them.
30% race fuel mix above 5k. 50% mix below 5k.
Always had Redline Synthetic Run through it.
Always been warmed up to 100-degrees at initial start-up and then heat soaked while i get geared up. Also warmed to 100 before it moves out riding period.
So here's the Down Low: As you have probably figured out by now I am very particular and this sled shows it in its appearance, clean-ness, and performace! I polish, wax sled, clean clutches every ride, etc....
I probably missed something and have lots of pics so if your seriously interested in buying please PM ME!
Thanks and need to sell asap to make a deal on a sc/fourstroke so PM me!
Updates Completed
Over 14k Build!
---MODS---
166 x 2.4 track
SLP Pipe/Can
Radiator Delete Kit
Goldfinger Lefty
Holtz Scratchers
SLP torq Arm
SLP push arm
3" Bar Riser
----DROPPED 2: $5750----Located in North Idaho!
