mountain cat 600 bogging/backfire
friend has mountain cat 600, not sure of the year but he says it idles fine but when he gets on the throttle it will bog and backfire:eek: he says his dad has went thru "almost everything" but i wanted to get some opinions so i can help get him running good. his dad thinks it might be bad gas so he is having him burn the current tank out and go from there.
D
Dec 8, 2008
56
1
8
40
unplug the kill switch on the bars and give it a quick try. I have had I think five failures now with these older kill switches!
M
Jul 3, 2008
1,870
659
Utah
It's more likely the kill function that is integrated into the thumb throttle assembly. It is an easy fix. Start by unplugging the whole kill switch loom (right at the base of the handlebars). If that cures it then cut the wire that goes to the thumb throttle assembly.
I don't remember which color wire it was, but you have a common/ground, and you have two other wires comming down to the plug.
Find the common, and tone for the kill switch, and it is the other one. Cut the wire, and put heat-shrink or tape around it so it doesn't ground out. Problem solved.
mtnxr
416
76
Colorado
Any updates on this. My wifes started doing this yesterday at the end of the ride. I had the stator redone last year and it has about 150 miles on that. Have not had a chance to look at it yet.
