I took out the jackshaft and see that the bearing is pressed into a collar. Just use a press to take the bearing out?
Also dont see an easy way to change the bearing in the top of the chain case that goes to the jackshaft. Its soaked in oil so I am not to worried about. You an feel minor drag on it but the ball bearings are quite large. To change that seal and bearing looking like you would need to pull the motor?
Not really looking foward to putting everything back together.
