Can anyone tell me what the difference is between the 3222205 and 3222220 lower pulleys?
Both have the same tooth count. The 3222220 came on the '14-'15 models and the 3222205 came on the '13 model. My guess, they found a different manufacturer that would make them cheaper.
Also, does know what length of bolt I need to use either pulley on a steel driveshaft? Thanks.
13 lower QD pully vs. 14-15: my understanding when I talked to Kurts Polaris (who makes the gear-down kit) is the shaft and splines were a slightly different size - they had the spline tolerance so tight on the gear-down kits that they had to manually file and fit them. I had both the 13 and 15 bottom gears at one point, and a very low mile 15 shaft, and they both fit well, and I took a video showing backlash on both and they were virtually identical. So either one should fit the axys. I sold both sets to guys with Axys sleds and I am sure I would have heard if they didn't fit well...Get ARP bolts for the QD pulleys. Yours will take an M10x1.25 40mm for the top pulley and M10x1.25 20mm for the bottom.
