The wife and I were out groomed trail riding all weekend and my new to me 2011 Pro RMK 800 ran great all weekend (scratchers down, 127 degrees).
Except....when I mashed the throttle to the stop or got on it hard down a long smooth stretch of road where I could really get on it.
Then it would immediately go into DET mode, every time.
Shut off, restart...ran fine, until I repeated the high speed/rpm process again, then it would go back into DET.
I bought the sled used last season with 2500 miles on it. Immediately tore the top end apart and installed a MTNTEK Fix Kit in it.
Inspected skirts for cracks, got a professional hone job, ensured proper ring gaps, etc...
I installed a new fuel filter, made sure the reeds were good, made sure I had yellow injectors, etc.
I am using Redline Snowmobile Oil in the oil tank, turned up the oiler 3 turns, and pre-mixed the first tank full after rebuild at 32:1 with Redline as well.
Using Ethanol plug only and premium fuel.
I waited till I got a good 100 miles on the top end before really getting on it and it has always run perfect at all other RPM's other than the very top.
When we were coming back to the truck last night I finally got on a smooth enough road to watch the Tach and it ran well up to at least 8,000 or so, then went into DET.
I only got to do it a couple times due to traffic on road, etc...but seemed pretty consistent to that amount of RPM's.
Could it be the clutch needing a couple grams of weight?
Could it be the Redline plugging new fuel filter from pre-mixing?
Too much pre-mix leaning out fuel through injectors? (Ran last tank with much less oil in it after 100 miles).
First fuel injected sled I've had, but I'm a pretty thorough retired aircraft mechanic....pretty careful attention to detail. :face-icon-small-win
Id appreciate any and all advice...I looked through the search function and DET's threads are all over the place, so if someone could help narrow down my search it would be a huge help.
