There used to be a ton of stuff available for my M series, but it seems like the new sleds just don't NEED the same stuff. Am I losing my mind?
Where's the sub $500 mods for the XM that work?
I have a great clutch kit for your 1 Fitty four.
This clutch kit converts more engine torque than you ever used before from your sled. The kit was step-by-step developed so the parts will work well with the efficiency of your 154 inch track.
The kit will dig deep and pull out all the muscles from the engine and has the ability to make them useful not only wherever, but however you are going to run the sled.
You feel a tight connection between your thumb and the snow. Drive the clutching as smart as you want; it’s a delight for accuracy in technical tree riding and then quickly accumulate more track speed in hill climbing.
When you want to drive more aggressive, the feeling is like having a gigantic hand on the front bumper, pulling you up even on the steepest hill “
woo hoo”, and then holding the sled back by strong engine braking when coming down.
When you need to drive for fuel economy on the way out; drive it gently and you will be rewarded with lower fuel consumption from lower engine speed at part throttle to arrive back at the trailer.
There is more 800 power under your throttle thumb, just waiting to be used.
Gearing
With your stock gearing, the kit will accelerate hard and help maintain track speed as you climb. You don’t have to gear up with my particular setup.
Elevation examples
21.5 grams in clicker 3 at sea level to 2000 feet. (Winnipeg elevations)
15.9 grams in clicker 3 for 4500~6500,
13.9 grams in clicker 3 for Cooke city 8000~10000 feet.
Here is what you would install (4 parts)
- 167/390 primary spring (3500 engage)
- Applicable pin kit
- 218/305 secondary spring
- D2 helix
Future - if you ever went to a big bore for the future (
872 Trygstad example) all you have to do is add flyweight for the increased torque and change to my 135/385 primary spring. The lower start force draws from deep within the 872 for 3300~3400 engagement and flare to 7900~8000 at your thumb's demand.
$334 CDN (estimated $249 USD today) (tx in Canada) + shipping.
info@iBackshift.com
