900 mountain cat 2004
B
burried
New member
Dec 22, 2007
137
48
i got this 2004 mountain cat 2004 efi
is it possible to install reverse on it without too much trouble?
Rixster
3,781
651
Springville, UT
Cat offered it as an option, I have seen a few king cats with it. I really dont know what all has to be done, something with the chaincase. Go to google and find a online micro fiche and see what a reverse was in 2004. should be able to find part numbers and prices.
R
Rush44
1,041
Flathead Valley, MT
Yep, its a new gear in the chaincase and a lever that gets installed off to the right of your ignition switch. I've seen a guy with it on his 1M before and he said it wasn't expensive (i forget the price) and it works pretty well. The weight addition is negligible.
arcticridr
319
45
Redding Ca
Yea like rixter said they made a kit for it but any I have seen have been a headache to say the least and get expensive when the whole shootin match grenades and takes out the chaincase!!!!!!!:eek:
Bill1010630
144
7
18
British Columbia
I installed reverse on my 03 900, you'll need a reverse kit for a 15 wide chain and a reverse handle kit.Took approx, 1.5 hours to install. Cat has a special tool for setting the engagement depth which is shown in the directions but it can be done if you measure the engagement depth before you install the cover then measure again through the opening provided for the special tool.
Bill1010630
144
7
18
British Columbia
The Reverse kit has an auto adjuster that must be installed correctly and checked periodically.Also you must use AC oil and change it frequently to remove any shavings that are present.A friend has had a kit on his since new and has had no problems at all.
J
JENSEN BROS
75
12
8
55
ELKHORN
I Have Put 4 Kits On. No Regrets. Works Great. Use Manual Tensioner. Put A Magnet On The Cover To Remove Metal Filings. If Any ?s Call Me At Night Or Weekends Mike 402-740-1663. I Didn't Mount The Beeper. Just The Bracket For A Stop. Pull Cover Once A Year To Adjust The Chain. Takes About 40 Minutes Start To Finish.
