Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 02-20-2019, 04:27 PM
cranktwister cranktwister is offline
Currently: just snowed 10 " last night winter is comin
Basic Member
cranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond reputecranktwister has a reputation beyond repute
Default 03 800 rmk no spark
I've seen a lot of posts with this problem but no feed back on solutions, sled just quit going up trail.pulled plugs to check for fire, plugs sparked once on first pull then nothing,towed home,disconnected single black and white wire to eliminate,tether ,ignition switch ,tors,checked stator resistance values,passed,pulled flywheel to check stator wires,good, pulled stator checked solder connections on back of stator good. but what I did find was remnants of a
old water pump belt wedged in between all flywheel magnets( filling the gap between magnets) removed all belt debris, reassembled, tested 1 set of spark to plugs then nothing. tested with known good coil and CPU, nothing, Any thoughts? Thinking secondary windings in stator bad, but passed RESISTANCE TO test? what gives? Thanks in advance, CRANK
Rate this post: Yes | No
  #2
Old 02-22-2019, 11:47 AM
jim jim is offline
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Chunks of debris in the stator, and the fact that you have tried CPU and coils, points to the stator. Even if you have continuity with a multimeter, you can still have issues with it running properly. Are headlights flashing when you pull the cord? Any indication of electricity being generated?
You could also have an electrical gremlin with a short or bad ground somewhere.
  #3
Old 02-23-2019, 02:57 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
The thermostat on top of the cylinder cap will go out every few thousand miles, and disconnect all electricity to the plugs. You can test for this defect by disconnecting the 2 wire plug to this thermostat, that sits above the engine, and then make yourself a small U shaped wire that you have removed some insulation at each end. And then plug those 2 end wires into each end of the 2 wire plug that you just disconnected, so as to connect the wires to each other. Electrical tape in place. This U wire will complete the circuit that gets electricity from the stator to the CDI, and then to the coil and then to the plugs.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2014 800 rmk spark plug issues Thread Starter — xpoguy Forum — Polaris: Pro-Ride Replies — 4 Last Post — 03-14-2014 11:17 AM
Thread — 2002 RMK 800 spark plugs Thread Starter — Tomkat700 Forum — Polaris: EDGE Replies — 8 Last Post — 03-11-2013 02:11 PM
Thread — 03 800 RMK No Spark! Thread Starter — ADL Forum — Polaris: EDGE Replies — 2 Last Post — 12-22-2012 12:02 PM
Thread — Polaris rmk 800 D8 not starting no spark Thread Starter — stiana84 Forum — Polaris: IQ Replies — 3 Last Post — 03-28-2010 01:30 PM
Thread — RMK 800 no spark Thread Starter — hoolee99 Forum — Polaris Replies — 4 Last Post — 01-11-2009 11:58 PM
no new posts
