Did you get your track installed yet?
Going to do it as soon as Elk season is over.
Note: this_feature_currently_may_not_be_available_in_some_browsers
Just a tip, The upper idlers on the timbersled set the wheels too far apart and wont keep track centered. I took off 1/4 inch off the upper tube so the wheels were set inward to keep track from walkingHere are some pics of the track installed. Turns freely by hand (it squeaks)but it is a tight fit....not too impressed with the factory cut though....it is narrower or wider in some spots along the edge. You can see how I set my drivers to run close to the inside of the track, as per Robbie. This will help keep it centered and prevent side to side movement.
Crazy question - why the power claw drivers on the 9116 track? Why not the std XP style?
Mark, what track # did you end up getting 9116 or 9219?
I got the 9219. The drive lugs are both on the inside of the track windows.
lol....ooops.....good thing it IS only october !! Talk to Robbie, he knows best.
There is definately an audible clunking as the track comes around the drivers when pushed/pulled by hand. Big lug,smaller more agressive driver, less clearance....bound to be more/different noises.
Install went well, should be on the snow sunday.:face-icon-small-hap
Mine clunks a lot just turning it by hand. You are suggesting to remove clips to stop the clunking?
Avids are not round drivers and removing a clip lets it rotate in an[ Clip-no Clip-Clip-No clip] pattern. Also the pitch changes between the windows where there is no clip and allows track to back slip every other tooth. This is only due to the Avid design which uses the tooth to drive the track not the side lugWhat causes the clunkikg? I dont recall the stock drivers and track doing that.
Is it the style of driver and clips?
About 50 miles of road riding in 2 feet of fresh today. All I can say is that this 3in is a keeper!!!!!!
