B
Been avoiding this thread because many wont be able to handle the truth.I get the opportunity to build up BB,s of many builders and have 860 and 880,s . Multiple motors of each. I,m a nut shell a cylinder with little porting will require larger mains and cylinders with extreme porting will run smaller mains, When an 880 well ported cylinder and the piston drops it flows much more air . That air in turn pulls more fuel with it since its a ratio.The same 880 without good porting has an air flow cylinder restriction and requires larger mains to compensate since air flow and signal are reduced. A well ported 880 also requires dropping the pilots to 15,s at altitude, The well ported 880 intake signal is much stronger than a 860 and is pig rich at idle/altitude with stock pilots.I have tuned many BB,s that love 480,s and 3 that require 540,s /560,s and larger.I,m not a fan of extremely lean jetting ,they have proven to fall off at the end of a climb due to excessive heat leading to Det. However they will be the snappiest motor off the line.Head design has some effect on jetting as well however not as much as the porting/bored carbs.the main jet size is not an indicator of HP.. Fact is a well ported motor with smaller mains can easily deliver more fuel than its counterpart,Yes there is a clear visible pattern as to the cylinder and the porting done and the corresponding jetting. motors that consistently run smaller mains are SHR.RKT , these have very good visible porting with exceptional air flow.,,,
wow that is exactly the kind of explanation I was looking for, thanks! provides great insight to what sledsrock said about vacuum signal. this helps those of us that arent as experts make sense of what others say in regards to the jetting they end up running on their bb's. And it also supports a point that I think is important for consumers; that main jet size is not an indicator of hp as some say, and that its the airflow dynamics that play a larger role in the final jetting. disproving the statement that if it doesnt take more fuel than stock it doesnt make power.
Explanative, first-hand-experience posts like that, imo, helps to make us all better tuners through better understanding, I think the builders benifit as well; if owners are better informed about whats taking place inside the engine, then the owners are able to better tune their engine, make it run great, and showcase the builders fine engine work. the owners end up not second guessing things so much and end up with a great running sled as a result.
what a useful post, thanks again :yo:
