Just curious as to those that upgraded to the 19t turbo last year. What were your impressions over the 16t, is it worth the change over the 310 kit. Any problems with it, throttle response, mapping ect and what did it cost?
I didn't notice much diffrence @ the bottom, but i still would consider the upgrade if boost is over 14.5PSI, 16T bottoms out much earlier.
I don't know if MCX changed their mappings for 19T, someone doing the upgrade better check with MCX.
TBird i know you are running the rapid bike and mcx display, i assume you had to change your map when you did the upgrade?
I found at 6500 -7000ft elevation the 16t will not build 17 lbs boost, at least mine won't. But then again mine still is running on the rich side@ 11.0 afr. Maybe the rapid bike should be my first step.
