03 800 mtn cat leaking fuel
T
Dec 5, 2009
85
5
8
leaking fuel when you pull the cord. Took skid off cant tell where its coming from. could injectors be stuck or floats?
T
Apr 20, 2009
557
241
Washington
Start by checking all of the fuel hoses that connect to the fuel pump in the bottom of the engine compartment.
Are you carb or efi? Either way I would start by checking fuel lines
C
Nov 26, 2012
20
2
3
50
Pull you air box out so you can see all the fuel lines look at all the lines. The one it more then likely is. Is the one from the fuel pump to the carbs. Or the ones on the bottom of the carbs float bowls. But if one is leaking replace all of them it will only cost about 25 bucks. Alot cheaper then a new sled. Good luck
