parting out 98 mach z lt
M
mngoat
30
Minnesota
can't seem to sell it out right so i'll try and part it out.
Here are a few items that it has on it.
809 engine w/ jaws pipes-never had any trouble with motor, has about 1900 miles on it, has only run with jaws pipes for the last 300 miles. Big john form the forum went thru the motor when the pipes were added and he said everything looked good.
These items have less then 200 miles on them
titanium jack and drive shaft.
Crankshop magnesium chaincase
Front fox air float shocks
Rear ryde fx shocks
fabcraft front trailing arms/radius arms(these are not direct fit on the mach z, had to modify rear mount(Not the sled but trailing arm) and put different spindles on, also had to modify sway bar.) all works fine and removes a ton of weight off the front of sled but probably should be bought as a whole unit, arms, spindles, skis(simmons), radius arms, sway bar ect...
Otherwise most other stuff is stock, sled is in wonderfull shape, seat is good, hood has just a few minor blemishes.
Make me an offer on stuff, located in Minnesota. Thanks
I'm going to keep the racepak gauge.(the old man wants it)
