SHR adjustable weights
BIG JOHN
1,146
Minnesoooota
ONLY in sled/on hill adjustable weight on the market!!!
PERFECT for the midwest mountain guy (5 min clutch changes) up to 10 grams in body of weight vs a bolt/washer in wrong location...
PERFECT for the TURBO rider (correct profile)...
PERFECT for ANY elevation (IN sled adjustability)...
ONLY SUMMIT profile adjustable weight....
967 ramp wasnt right, new 965 ramp only marginally better (only 1 gram heavier were needed) wont work for low elevation...
I guess that sums up what a guy NEEDS-BJ
BIG JOHN
1,146
Minnesoooota
Ace- $295 for summit kit...
chadly- Im going to contact all my turbo customers soon to chat about the upcoming year and what you would like...
BIG JOHN
1,146
Minnesoooota
Are there any other changes need (springs, helix) say going from 2000' elevation to 9000'?
SHR kit comes with new QRS spring, stock spring has been wrong since 2012...
ALL tuning is IN the weight...5 (FIVE) minute change for ANY elevation!!!
After weight is loaded per elevation you fine tune with pin weight/clicker if needed (those still work!!)...BJ
yosh30
235
33
What makes these better than the ZRP adjustable weights? just wondering the difference?
BIG JOHN
1,146
Minnesoooota
can you adjust the ZRP weights IN the sled ON the hill??
can you use the clickers?
can you fine tune with the pivot bolt weight?
are they the summit profile?
tools to access my weights are supplied with kit...BJ
sledheadracing on FB has videos/pictures etc...
BIG JOHN
1,146
Minnesoooota
SUMMIT profile...
Base weight better than stock...
Can add up to 10 grams IN weight body...
Adding 25-30 grams to pivot bolt does not work, IF it was that EASY why did BRP make 6 new heavier weights and ZERO new pivot bolts??
I had a Pdrive all winter 2016 on a 800 etec...
Learned flyweight clutching from Olav Aen/Indy Dan years ago...
TRA guys???-BJ
BIG JOHN
1,146
Minnesoooota
ONLY summit profile perfect for YOUR turbo!!
every 2017 needs a reclutch....
almost every 2018 does too (they changed parts but didnt FIX the problem)...
the 175s are worse than the 2017s...
call for details...
keithw
249
117
BJ - I had all the updates to my 17 850 done except for the fixed sheave. You recommend replacing the fixed sheave as well? I am down to try your setup.
BIG JOHN
1,146
Minnesoooota
the 18s did get new clutching but didnt address the problem...
the inner sheave is a good idea but for $375???
add venting (2cool) add proper clutching you will be fine-BJ
C
caper11
2,055
2,170
Northern alberta
I installed these in my neighbors 850. This kit is well thought out and top notch quality. Ive said this before, the pDrive should of been designed this way! Well Done BJ!
bjd68
322
130
Abbotsford BC
So I have a 2017 165 and ride at 6000-7500 ft will this be good for me sorry not familiar with the p drive at all yet ? And does the kit come with everything I need to do it myself ? Thanks Brent !
BIG JOHN
1,146
Minnesoooota
it mostly does BUT you do need to understand the clutch...
youtube has a few videos, buy the 2017 DOO race manual and your good to go-BJ
