Clutches not parallel, motor mount adjustments?
W
Jan 14, 2009
25
2
3
48
Ok, here is the setup.....
2012 Proclimb, Team Tied secondary with TKI belt drive, 15 shaft, Skookum motor mount plate.
New motor rear motor mount, clutches aligned within spec.
From what I can tell, it looks like the motor is turned slightly and the clutches are not square to each other. What are my options? Loosen and notch motor mount holes?
boondocker97
4,074
2,792
Billings MT
Loosen all the motor mount bolts: under engine, mag side, and PTO side. Motor side and chassis side of the mounts. Then see if you can twist the motor enough. If so then lock them back down. Might have to totally removed bolts one at a time and re-apply Loctite.
W
Jan 14, 2009
25
2
3
48
Front to back isn't the problem, the motor is twisted sideways a little, will see what headway I can make with all the motor mounts.
