Is this were peopl are machining down?
Rather than machine down the track shaft, would it be possible to shim the brake Caliper assy by using a few flat washers?? I've never had mine apart but looking at the parts diagram it appears that installing a few flat washers as shims may work??
No, I don't think the 08's had the issue, but while you are in there, why not!
I took the dd apart 2x, inspected it, and cleaned it. Put new lube in and bolted it back in. The first year the original fluid was pretty dark, and the second year I was amazed, it looked almost like new gear lube:face-icon-small-sho
I think it had something to do with getting rid of the reverse actuator and putting on the lever... very little chance of ever not getting it into reverse all the way with that mod
I have a 2010 M8 with 1,250 miles and pull my DD Drive today. Just some rambling thoughts:
1) Many thanks to MM 700 for explaining how to pull the DD, couldn't have done it w/o you.
2) Just to clarify, the 16 mm bolt is accessed thru the "Drive Shaft", not the Jack Shaft..- Had me scratching my head there.
3) My DD didn't just pull out - It helped to put the 16 mm bolt in a few threads and wack on the extension and drive it out.
4) My oil and Bearing were in perfect shape, meaning I probably don't have the "narrow tunnel" condition". I ordered up the BDX 5203 bearing anyhow.
5) The old bearing and spacer will let the new wider 5203 sit exactly where the old bearing was.
6) So why machine the shaft? I dont' think there is a need unless you have the "narrow tunnel"?
7) Some say shim out the brake caliper - Would the same be accomplished if you shimmed out the DD case? Dunno, I'm asking.
8) For me, I'll put it together carefully with the new 5203 bearing....Will not machine down anything unless I see a clearance issue or "binding"....
Will report back soon........See you on the Hill
Thanks for the 4203 feedback. I was considering one of those for mine.
I did the same last year, installed a 6203 for now and will inspect after 500 miles or so.
I'm still wondering about the lubrication issue and would like to hear feedback from those that installed a 6203 without the seals. Seems like total failures of the 6203 are few (any at all?). On mine the lefthand seal was out and the bearing cage was screwed, allowing a few bearings to "free float" in the groove, but I'm wondering if the additional dd lube now getting to the bearing was keeping it alive.??
I'm not thrilled about the machining of the shaft, and it seems that the general recommendation is remove the dd, install a 5203, put the cover back on and put the dd back in the sled without machining.
I assume the 5203 is durable enough to handle any additional side loading but I'm wary of the strength of the case cover to hold it all in place but I guess there haven't been any failures of the cover.???
