Low elevation BD Sidekick X hesitation 2016 Axys 800
L
lshobie
346
145
Hi guys! I've upgraded the sidekick kit to the aux injector kit with unable box. I have a blurp when I punch it from a standstill - if I hit it while im moving it pulls hard with no issues. If I back right off and punch it it blurps.....here's the sounds: rmrmrmrmrmr (idle) then I punch it and whizzblurrppppppwhisssszzzzzz!
Elevation - sea level
Does not det
2016 axis 800
tunable box
aux injectors
timing key
100LL fuel
Low compression heads
upgraded 2018 cover and thermostat.
Clutching:
indy dan turbo weights
turns 8450 at WOT
indy dan primary and secondary springs
Indy dan arm ripping helix
I jumped the box plug because the kit didn't come with a jumper - to switch to the boondocks map.
I have a Bully Dog tuner
Larger avid drivers
TKI belt drive
I'll try adding larger weights, then different helix, then different springs just to eliminate the clutching. I'm almost wondering if it is over revving but not used to that blurrp - any blurp I had in the past was a det issue.
Any help would be appreciated - I am riding the chic chops in 3 days!
Cheers/.
Louie
