How many of you trimming the bottom's of your clutch covers? Rasmussen says cut, Norona says dont cut,,,, I'm kinda lost on this one :face-icon-small-con
Note: this_feature_currently_may_not_be_available_in_some_browsers
These things build so much clutch heat I don’t think it matters either way.
Ok, so cut the tab at the rear where the small rectangular piece of is on the bottom.
Yes exactly, if you look in the left foot well with the cvt cover installed you will see it blocks that left footwell a bit, just cut around the foam, not any more, the rest is structural there. that will increase the air out, which gets rid of the hot air, and belt dust as well.
Anyone else have a look a like crack on bottom of bulkhead? Is this brp quality control or designed like that!! Should they be welded up!!
Just picked up 850, this belt cover is a joke to get off, need to be better than that, or it will get a full mod delete, is there any trick to removing it or something we can cut off to make it much quicker..
What about all the engine covers, the big one from throttle body's to secondary.. Why is engine to shielded from airflow? Is this a noise compliance from factory or is needed with belt cover for air movement..
I'm use too having maximum air flow threw engine compartment with vents and holes.. This thing is like Fort Knox for air flow..
Cut the bottom section that has the piece of foam on it, it is 1 inch by 2 inches it allows the air to escape, the guys who drilled holes everywhere might as well take it off, the cvt cover is designed to pull the air out through the left foot well. if you cut the bottom off you might was well take it off, something I don't suggest, it has nothing to do with belts blowing on 2017 model years some guys went through. If it was then it would have happened on the 12-16 model years. Keep the cvt cover intact but take out all foam and felt and in clutch area...
So a question. How can the clutch suck cold air and exhaust hot air out the SAME opening.
