Has anyone tried running the slp pipe kit and T-Sled intake on 09 800. I know SLP says no fuel box at any elevation with their pipe and high flow intake, but what about with a timbersled intake? Any Help
keep them under 1300, easy to use, glance at them once in a while, the koso turn to red when they reach they upper limit temp, that u set on them, my turbo would run 1350, even saw 1419 once was always afraid it would burn down, but never did, i was always worried about burn down ruined some of my fun.
Aluminum melts at 1300*
With that said the 800 gets away with a lot more than some others, you should check plugs and wash. I ran mine with egts stock and got some readings then when I put the pipe on I tuned it to get the same numbers and try to mimic the stock mapping. worked great.
I havent seen any difference between stock intakes and slp intakes unless there was tons of snow on the hood then the slp would draw hot air from under the hood a little better but as far as performance there was no improvement, in fact they ran so good with the stock intake no one around here bothers with them but I wanted to loose the weight with the bdx intake and put it on and tuned it in and I can honestly say there is more power, weather its from the 8lbs lost or more air I'm not sure but I wouldn't go back and never cared for the t-sled or slp intake.
Fuel controllers arent that hard to use, you just have to mess around a little bit and it starts to make sense.
