B
What is the highest I can raise my bars without having to rewire and replumb on an 01 mcat 136.
Thanks
-B
Thanks
-B
I have a 3.5 in Rox riser and the electrical is long enough but i lenghtened out the brake all you have to do for that it go to and auto parts store and get a premade section of brake line i think the shortest is 6 to 8 inches and put it on at the brake caliper and coil it up because its more than you need and I also have a two inch higher steering post so i have 5.5 inches of riser and the electrical is still long enough just barely
I did pretty much the same. I went to the auto parts store and bought the shortest piece of steel line they had, then I had them cut it in half and flare the cut end. Ended up with a three inch line and coupler to add on to my original. Worked out great. Cut a couple nylon ties and did a little rerouting of wires and cables.
