1
The Axys is a very nice sled, but I thought it would be cool if everybody posted their wish list for easy changes to the 2018 Axys rmk. In order the changes that I think would be the easiest/cheapest fix with the most impact:
1) More accurately calibrated TPS including base setting. Buyers provided calibration numbers on purchase.
2) Better electrical connections to exhaust valves. Corrosion seems to be an issue.
3) Enlarge the stock dash storage deeper into the sled and seal it. It is intended to thaw a pair of goggles but they don't fit. If they get smashed in they still don't thaw.
4) Change spindle design. It does drag in the snow excessively when the sled is on one ski. They have also been occasionally snapping off. Follow the aftermarket.
5) Better shocks on non-le model. Not sure what the best bang for the buck is but at least some different valving should be cheap with a very big impact.
6) Center the motor in the chassis more. When you lose 20 lbs of exhaust off the right side of the sled it gets way out of balance. (Turbo guys might not like this but it is down on the list)
I hope you listen to these folks Polaris!!! Let's hear everybody's ideas!!
